idea to stop brake levers and gear shifters bending
not sure about this.. picked this up on the TW forum - thinking about tryin it on my CRM since I am always getting bamboo in my back brake lever!
basically you get a bit of cable of the right length and crimp a loop thru the end of each lever..
has anyone else tried this? whats the success rate?
Re: idea to stop brake levers and gear shifters bending
It looks like somethin that will catch the bamboo nicely!!
I cant see the point of it, how could that stop anythin bendin?
i can see it might stop one situation happening;- I've had bamboo / vines come in-between the brake lever and the clutch case a few times.. its tended to jam the back brake on,, so this might actually stop that happening..
bamboo and vines are the bane of me life..,,, the vines here would defiintely let tarzan swing from tree to tree, they really strong!
I was going down a trail today vine got caught on the handle bar - I didnt even see it! totally wrench the bars I end ed up off the bike again ( actually it pinned my leg down and took me a while to get the bugger off me! )
I'm gonna have to widen the trails a bit more I think!
Only of any use if your levers stick out a lot like on older bikes, a bashplate does a good job.
I guess my levers are bent!helisupp wrote:Only of any use if your levers stick out a lot like on older bikes, a bashplate does a good job.
I might give this a go ( when I get my bike out again ) becos it is has suffered from this quite a bit!
and on the wheel hubs,,, I'm getting lots of vines and brambles wrapped around the hubs,,,
thanks mike - i might go there.... cos by the time I got the cable and the crimping tool....
- Bike Owned: 250 MK3
I have similar on my brake pedal but my pedal is tight to the casing ie hardly protrudes so not likely to catch bamboo!
[quote="andrew19"]I have similar on my brake pedal but my pedal is tight to the casing ie hardly protrudes so not likely to catch bamboo![/quote]
Not in Swansea anyway.......
isnt the problem sheep there?
back on a serious note - I put on a luvly straight gear lever not a month ago.. its now well banana'ed
I guess I need to stop bashing rocks now - or get somethin on me bash plate to deflect,,, my bash plate is bashed to buggery! its wrapped around the frame well an good! an sort of a bit wonky too!
havent had a ride in nearly week now! too busy with work - an stuff.. I have saturday booked! but still havent fixed front brake!
Why do you need a gearlever, you seem to be in first all the time...............
hahahah - yeh,, good point!
Set the lever much higher than it would normally be, yes I know it's a pain, but at least it's out of harms way, and likely to be un-mollested by rocks.
Well spotted
