Off i go again
Hallsy
Re: Off i go again
Post by Hallsy » 31 Aug 2011, 19:43
Oh I see, I hadn't read a great deal but it seemed as though most just accepted the forks were a bit soft.
I didn't realise aftermarket springs were available.
Either way, you can't argue with WP :D
Bike Owned: KTM 200 exc
Re: Off i go again
Post by back off road » 31 Aug 2011, 21:05
or a rolling chassis with them fitted for the price of a fork service :D
Re: Off i go again
Post by back off road » 02 Oct 2011, 19:03
the comparison between std inlet and the new one so the 35mm pwk can go on.
Std one is on the left with the tiny hole
Re: Off i go again
Post by back off road » 02 Oct 2011, 20:07
it is a cr250 inlet ,im just showing the difference in size of the inlet :)
got the inlet and reedblock with boysen 2 stage reeds for less than the price of the reeds :D
Jeram
Re: Off i go again
Post by Jeram » 03 Oct 2011, 00:23
best part is that the vforce3's line up perfectly with the inlet passage in the CR manifold, but dont line up with the CRM manifold.
as you can see if the pic, the cr one is off to the side a little :)
lgingell
Bike Owned: CRM 250 AR W
Re: Off i go again
Post by lgingell » 03 Oct 2011, 21:13
may not be of any use to you - but the 43mm wp forks (ktm exc any many others) fit straight into the crm yokes - no machining
Re: Off i go again
Post by back off road » 03 Oct 2011, 21:28
cheers but the yokes are sorted with the bigger forks now, any ideas on the rear shock appreciated ;) as long as they are cheaper than a hagon :lol:
Re: Off i go again
Post by back off road » 04 Dec 2011, 14:41
front sorted , long range tank fitted , carb ,inlet and reedblock fitted
and the bike runs :( like a bag of s**t :lol:
rejetting time or std carb back on for now
