What size tyres you running
admin
2016NWAA
2016NWAA
Bike Owned: AR
Re: What size tyres you running
Post by admin » 15 Feb 2012, 10:30
how did you space the sprockets out ? washers behind the rear ? what about the front ?
correct about chain lube
Post by knackeredMk1 » 15 Feb 2012, 13:32
I had a ring of stainless steel (as I remember ~1.5mm thick) made to cover all the bolts but washers would do. I also had several thicknesses of plates made to space out the front to get the two srockets perfectly aligned. BUT mine is a Mk1 so has a bolt on retainer for the front sprocket. Can't see a way to do this with other models :? . Maybe the tolerances are such that you can space out the rear without doing the front.
You can save 1.5-2.00 mm by using a non-oring chain, which you don't need anyway and also doesn't loose as much power.
admin
2016NWAA
2016NWAA
Bike Owned: AR
Post by admin » 15 Feb 2012, 13:42
Hmm interesting. i need to go and get mine back asap to offer it all up and try it out.
just need to get some damn mirrors for it before i want to use it on the road now
Jeram
Post by Jeram » 15 Feb 2012, 20:36
did you have to run a non-oring and offset for your 150? shite...
mine fits nicely in the stock mito wheel, oring chain, 5mm clearance to the chain edge
guess it purely depends on the wheels sprocket offset amount :S
