Crm slow acceleration?
Darrylmartin
Re: Crm slow acceleration?
Post by Darrylmartin » 23 Jun 2015, 20:27
Thanks for the info guys.. I am going to do a compression test tomorrow and I'm going to check jet, and plug
Darrylmartin
Post by Darrylmartin » 25 Jun 2015, 20:13
Ok so I done a compression test..... It's reading 95psi.... That's low right? Plug was a good colour tho... :-/
Post by fallenmikethebike » 25 Jun 2015, 22:03
That's very low, 150 psi is more normal.
Darrylmartin
Post by Darrylmartin » 25 Jun 2015, 22:06
Ok... What would be the main cause? ...I suspect the last owner replaced piston with same size but not rebore.....
Post by knackeredMk1 » 25 Jun 2015, 22:19
Take the top end off to check but probably rebore and new piston and rings.
Darrylmartin
Post by Darrylmartin » 28 Jun 2015, 07:16
Ok will do I'm guessing leisure trail is the best place to go?..... Also I think what happened was the guy that had it before me did not run in the last piston.... Sounds like it has piston slack.. :-(
