New Project (Gwyns old bike)
- deano123
- Bike Owned: Two , mk2'S
started to strip is down
exhaust has many big dent in so im going to blow these out will provide more photos of how i do this when i get to it (basically block both ends off, pressurise it , heat up the dents and most of the time they come out)
while the enigne is in bits ive decided to do some basic porting work to start with
which basically blue print the enigine to how it should have been from factory. As these enigne like most are formed from casts it usually means lots of lots of imperfections are left in the casting. These imperfections are the rough feeling you see on the outside of the engine.
What we are interested in is removing this but from the air pathways eg, transfer ports,inlet port and the crankcase (where the crank sits) also to some degree smoothing out the exhaust will also help a little but your main gain is from the others.
First thing that needs to be done is the port matching. This means matching the transfer ports to the crankcase. So bolt the barrel down to one side of the crankcase show below (make sure barrel dowl is in place)
- deano123
Re: New Project (Gwyns old bike)
Also take not that the base gasket will also have to be trimmed when fitted to the motor as it will overhang , it overhanges even on standard cases!!
Next step is to polish all the ports to speed up gas flow!!
- Active Rascal
- Forum Ghost
- Bike Owned: CRM 250 AR
Good stuff!! Lots of pics will be great. I thought the transfer ports should be relatively rough to ensure the fuel mixes well?
- deano123
some beleive this to be true its called the golf ball effect (pimples in a golf ball aid it through the air) but in reality it doesnt work , look in any race engine that has been tunned and you will find smooth ports. Also tried it back when i was road racing 250 MZ's on the track. As i rode for one of the tunners, so gathered and picked up alot through the years of racing them. Now racing 09 triumph daytona 675 at BSB.
Any way the smoother you can get the ports the quicker the air and fuel will flow resulting in more power through rev range and increased throttle responce.
next stage and more photos to follow
- Active Rascal
- Forum Ghost
Cracking stuff! Keep the pics coming....
- deano123
Right now for the port polishing
Get yourself down to halfords and buy what they call the wet & dry project pack, intails a few sheets of paper of different grades. Start off with a low number paper like 300 or 400 with water thn move up the grades untill you finish on 1200 or something by this time depending on how long youve spent on them should be nice and shiney. My advice get the wifes best towel over your lap sit in the living room and watch the footbal oh and a can or larger. This can be a long and boring process depening on how well you want them.
- deano123
bit more work to do to the transfer ports on the barrel but you get the picture
Right now got better pic so you can see what needs to be done transfer wise on the barrel
in the black square is the imperfections left over from the cast and these can easily be removed , but those pits or small holes in the red saure cant be removed without to much work and and not worth the effort will take days depening on size.
looks like the cold dark winters nights are fully booked
- deano123
did it over xmas , just about done now, just waiting on bearings and bits from honda to turn up now
