AR Project Started
Only Site supporters can create new posts in this section. A section to display all your bikes, and biking history. Feel free to share your history here and picture whoring. This section is not 56K friendly, let alone 2mb broadband friendly either.
helisupp
Bike Owned: CRM AR (4)
Re: AR Project Started
Post by helisupp » 17 Oct 2012, 23:54
I saw your luvly cases a long time ago before I completed 1st bike, and will be at Redditch in the new year with 5 clutch cases for powdercoating.
Just need to order the water pump seals..........next time I call Tom at LT.
Active Rascal
Forum Ghost
Forum Ghost
Bike Owned: CRM 250 AR
Post by Active Rascal » 18 Oct 2012, 08:16
Mark,
As you know it's a bit of a git job to do as you have to strip the case down, that's oil pump and all bearings and seals. Also as you know those water pump seals are very expensive!! I had mine done in Burton but apparently it's not the proper powder they use but is all they can get in the gold. It does chip and wear really easy, but to be honest I only really did it for the final photos to make it look as new as possible... Not that it would ever stay like that.
helisupp
Post by helisupp » 18 Oct 2012, 09:43
I may just rub them down then and have them 2 pack painted, leaving the water pump and internal parts in situ.
Will experiment on a spare casing first.
Active Rascal
Forum Ghost
Forum Ghost
Post by Active Rascal » 18 Oct 2012, 10:24
Somebody on here painted just the actual clutch cover (round bit) whilst on the bike by making a circular template/mask. Not sure what paint he used but it was a good match.
helisupp
Post by helisupp » 18 Oct 2012, 13:46
Mammoth200
Is this what you wanted.
mammoth200
Bike Owned: CRM250 mk2 1992
Post by mammoth200 » 18 Oct 2012, 14:50
Brilliant! Cheers for that :)
helisupp
Post by helisupp » 18 Oct 2012, 16:40
It was amazing how much crud came out of the carb, blocked jets etc.
Will be cleaned and reassembled with nice new hoses.
All stripped and cleaned
Ready to fit
helisupp
Post by helisupp » 21 Oct 2012, 17:26
Couple of hours work (yes I know Its slow) had to cut it short, just bought a good shock, Rad, Front Master cylinder, engine plastic covers, and numerous other parts, £80 bargain..
Now lets clean the wiring, where do we start.
helisupp
Post by helisupp » 28 Oct 2012, 19:43
Can you believe it, it took 6 hours to clean, electrical check, clean every pin and connection and rewrap the wiring loom with tape. :x
Loom and a couple of items now fitted, its a sod fitting the loom tightly when rewrapped, left in a cold garage overnight, had to warm it near a radiator and then fit.
The dreaded side stand switches are fitted to all the bikes as I like them in standard working condition (I still need one more that works as one is a duffer).
Brakes now being refurbished (bit of a mess), the calipers I am using have been painted metallic gold and look in a sorry state, so paint stripping and rotary nylon brush being prepared.
jompy
Forum Ghost
Forum Ghost
Bike Owned: MK2
Post by jompy » 30 Oct 2012, 22:17
Looking good :)
where did you get your new hose's from for the carb ? stupid question i know !
i also need new hose's for the oil pump , haven't looked yet so i thought i'd ask seeing as you've
rebuilt so many .
helisupp
Post by helisupp » 31 Oct 2012, 19:52
Carb fabric covered water hoses purchased off of ebay. Just search this site as I have posted this before.
Just fitted new ones today
helisupp
Post by helisupp » 31 Oct 2012, 20:01
When trying to install the hoses........no lower carb pipe fitted to LH radiator, must be a MK3 rad not an AR rad, was on one of the bikes, not sure which one..........strange :oops: .
Just fitted a spare rad, the radiator you see in the pics is for sale if anybody needs good MK3 LH radiator, with lower hose for £20.
helisupp
Post by helisupp » 02 Nov 2012, 19:30
Well its been slow due to the amount of cleaning and inspecting.
This is the brake system being used on the bike, needs a lot of TLC, new master cylinder seals, pins, pads, pad springs etc, and a very good clean up.
Should be done this weekend, so will post an "after" picture showing what can be done with a bit of WD40, brake cleaner and a rotary nylon brush.
Beanie
Post by Beanie » 06 Nov 2012, 18:35
Loving your work Mark!
helisupp
Post by helisupp » 20 Nov 2012, 19:27
Nearly completed just needs chain, plastics and stickers. Active Rascals old bike reborn
Loads of parts purchased for this one, its the last one, but still looking for an original AR Headlight.
