Fishy, bike all dusted down ready for summer
Re: Fishy, bike all dusted down ready for summer
Wow!!
How did you get the crankcases up like that?
Its spotless!! Fishys is like that under all the gunge and bamboo
Ya must have plenty a spare time man
It takes about 2-3 hours to do any CRM engine that is on a bench to same standard using WD40, nylon rotary filament brush and drill. It makes an awful mess when working on engine but worth it, the wheel gets into every nook and cranny.
Then apply ACF50 and wipe it in, then wipe it off, job done.
6 engines done so far (including the spare) and a couple were rough to start with.
Not sure if the rotary brush removes bamboo though.
- Bike Owned: 250 MK3
Do you have a link to a rotary filament brush? I need to go out and buy one ..... or two
Just go onto ebay and type in "rotary filament", several types of brushes from "Silverline" will be shown.
Best to use a 100mm wheel, a cup brush and an end brush, not expensive, you will not wear them out.
Before you use the wheel brush on the engine use it against a vice or something for a minute to start the bristles bending over (with WD40), they are too stiff to start with.
ha! so if I bring my bike to the hotel lobby when Hels comes to HK is he are volunteering?
actually I did have a go when I read your thread - I just used WD40 - and it has come up quite nice like - a year near on later barrel and engine look kinda ok
- shame I couldnt be bothered waiting for the frame powder coat cos frames whats really letting it down..( ok an the plastics too.. )
I am vaguely considering dropping the engine again and geyting it coated... but it was gonna take 3 weeks.. an I will probably smash it on a rock anyway...
Hel's flywheel cover looks nice tho - I am considering goin to a paint shop an buying pink fluro paint to spray things that might fall off...
today I had a lucky break - massive rain storm here on todays ride.. and what to I see when I "stopped for a rest" in what was once a dry stream bed? my sprocket cover washed up against some rocks leaves! lost it about 3 months ago! result!!!
must say if I was in the UK I might buy one of Hel's AR's - but really it would be wasted on me - cos I will find the only bamboo in the east midlands guaranteed!
