Sprocket Gaurd
Sprocket Gaurd
Hi Guys
Does anyone know what front sprocket/chain guard would fit on a CRM 250 Mk 2 .
I want to put an aluminum/trick one on ,but nobody that I can find lists anything for the CRM.
Re: Sprocket Gaurd
Not sure if other bikes guards would fit. You could try an XR guard but it would be a total gamble. Maybe get a local fabrication shop to make one using the original as a template?
Re: Sprocket Gaurd
I've seen sprocket guards advertised on Japanese sites........
Re: Sprocket Gaurd
not sure if ARand Mk2 are the same so check first!
http://www.ebay.co.uk/itm/K-T-Sprocket- ... Swc49Y8hy1
Re: Sprocket Gaurd
AR part no and mk 2 part no are different but covers and engines look identical.
Re: Sprocket Gaurd
I don't think there is any difference.
Re: Sprocket Gaurd
From memory, the A.R.s are in a gold colour,whereas the MK2 are in silver.
If you're not to hung up on originality, it's worth drilling holes in the cover to make access for gentle jet wash cleaning that area easier.
