Chinese carbs
Chinese carbs
Has anyone tried one the Chinese pwk copies? They seem to cheap to be any good?
- Bike Owned: Mk3 CRM
Re: Chinese carbs
I haven't tried one I'm afraid and I'm not sure I would bother either. Where about are you? Why not use the money for a new carb to get someone to look at it for you.
Re: Chinese carbs
Ah well I've ordered one anyway if just to be able to make up my own mind about them, seems like a bit of pot luck from what I've found online. Some people think they're ok others don't. So only one way to find out I suppose lol.
- Gammakeith
Re: Chinese carbs
I fitted a (very) cheap Chinese carb copy to my wifes Honda H100. It went straight on and ran perfectly. The float leaked after a year later but that was probably due to the E10 she was using. The float from the old carb fitted fine
Fingers crossed the PWK works!
Keith
Keith
Re: Chinese carbs
It arrived today and it looks absolutely spot on even got serial numbers. Got to make a new throttle cable I believe and get a reducer to connect water hoses together then hopefully I'll have it running again.
