fitting handle bar grips?
Whats the best way to get new handle bar grips on? is there anything you can ease them on with that will evaporate away? on the clutch side the grip has a collar at the swithchgear end? is this for a small tie wrap?
Jack
Jack
Re: fitting handle bar grips?
Fill them with hot water and empty. Then put straight on.
Most solvents will evaporate away, and, you also get some chemical reaction with the rubber that acts as a glueing agent.jack_knows wrote:Whats the best way to get new handle bar grips on? is there anything you can ease them on with that will evaporate away? on the clutch side the grip has a collar at the swithchgear end? is this for a small tie wrap?
Jack
It is better to get some locking wire and use that as opposed to a zip tie.
If you look at the grip, there is usually at least 3 pre-incorporated places to lock wire your grips on, and, I personally can't emphasise enough the importance of doing this.
It has been my misfortune to see several very nasty accidents from grips, slipping off the bars at inopportune moments and riding with a moving grip is soooo, tedious.
+1. I wire my grips on any bike I have.
I always use hairspray to fit new grips
You could try shutting the garage door, that would keep the draught out, you might not need to use it thenboundy wrote:I always use hairspray to fit new grips
Yes, I have heard of people using the spray for that, and I checked the Missuses can out, but it only guaranteed it for fly away hair, not grips.
Does work though .
Many thanks for the tips, (hair stayed in place so did not need the hair spray lol) but did use the hot water tip and worked fin! just need some locking wire now!
Jack
Jack
so whats the best way to get them off without cutting them off ?
'removal is reversal of installation'
well if you used heat to get them on then I would try heat to get them off - maybe a hairdryer (or heat gun if your garage is so equipped...)
Regards
SkidMark
The most successful way I have found is a large enough, open ended spanner behind the "doughnut" open end section, and plonker with a hammer.
- purple rooster
- Bike Owned: Mk3 prospec
ive always had to cut em off cause i use superglue to stick em on! never had one move yet!
- josh mk 2 crm
I know it sounds really dodgy but I use a bit of petrol and it works a treat!
me too, ive always used petrol, works a treat
- Davey Munroe
put the air line in the grip. Press the button an voila. Flying grip.
