are the CRM's front brakes pants or is it mine?
Re: are the CRM's front brakes pants or is it mine?
haha!
you as well NJ ! - I'm sure I heard a story about handlebars this weekend.
let me see I dropped mine about 1 times today.
and another wheelie flip!
( but I have found the perfect place! )
will post some vids later..
ps - it must be bocos the hand guards have moved right? 2 levers in 2 days - its almost as much as I spent in petrol !
mind you must be learning eh - took my mirrors off when I hit the track today......
ps 1 times = is a typo - more like 10 times!
- njhardy
- Forum Regular
- Bike Owned: CRM250 Mk3
Yup- nursing bruised ribs and a nearly broken thumb from a fantastic 'tank slap' with an 'over the bars' finale!! -Need to practice my style points!!
Get them damned mirrors off- they are killers off road!!
,njhardy wrote:Yup- nursing bruised ribs and a nearly broken thumb from a fantastic 'tank slap' with an 'over the bars' finale!! -Need to practice my style points!!
I have a mirror that folds down from the perch on the handlebar, so no protrusions to get in the way when the tarmac finishes, but easily flipped back up once back on the black top.
- njhardy
- Forum Regular
Yeah- seen those foldy jobs, but not sure how useful they are. The 'under the bars' ones look good, but are just as bad for ripping your kneecaps off. I just prefer no mirrors for trailing- they just catch too much brush and are painful when you fall on them. I had a friend break multiple ribs on his. I even think no mirrors makes me look around much more and be more aware of traffic..... However, it does give me big blind spots, especially with a neck brace on... Try to wear an open face helmet when riding in town.
- Pie-eyedpiper
- Bike Owned: Mk 2
My front brake was crap and bled it countless times, new bad but still bad.
Fitted a new disc and it is now great with full pressure feel at the lever on half the stroke.
ohh bugger i was wondering that too!
can u tell from this photo if my disk is ready to change?
altho - for sure the fluid is shagged- hoping a clean and bleeding the brakes will help..
min thickness is 4mm I think
- njhardy
- Forum Regular
The grooves in the metal disc and ridge on the edge where the pads rub tells me it needs changed- I did both of mine last month and put cintered pads on too- they are much better. The pads nowadays are almost tougher than the discs themselves, so wear them away after a year or so of heavy use...Saying that my YZ brakes were just awsome compared to the CRM's.
u think mine need changing?
Judging by the rest of the brake system, its definately worth changin it. The new pads just wont work 100% on an uneven surface like that.
Go on dude, spend your riches
arggh!!!! up to my neck in it now - wished I'd never started moaning about the brakes...
well luckily they arent that expensive! ( 22 quid to 35 quid to 50 quid.. ) ( my CRM was pretty cheap - project kind of bike luckily )
http://www.ebay.co.uk/itm/HONDA-FRONT-B ... 423wt_1115
thinking I will tackle cleaning and checking the seals on calipers first...
but actually held up since waiting for brake hose,,, makes sense to do it all in one go,,,
else I'll be bleeding the bleeding brakes for bleeding ever..
- njhardy
- Forum Regular
Seals should be OK, unless perished and then you will be losing fluid. Best thing- new discs (I paid about 30 dollars each disc), new pads (15 dollars each) then bleed the system and new fluid- 5 dollars and 1/2 hour time.
Mind you, mine were much better, but I still can't pull a 'stoppie' on mine. In my view these particular Nissin brakes are just not very good (compared to others I have used, which would throw you over the bars)!!
