DT200WR versus a CRM250?
xander77
Forum Regular
Forum Regular
Re: DT200WR versus a CRM250?
Post by xander77 » 21 Jun 2012, 21:21
knackeredMk1, your right mate should know that by now! duh!
Its only that I went on the DT200 and it felt way better top end than mine! but then that would`nt help on most lanes! CRM its ace!
Mark
Jeram
Post by Jeram » 30 Jun 2012, 06:54
there are many things that could be killing your bikes top end power.
your piston/rings may be old? check your compression
clogged air filter
clogged exhaust and silencer
fouled plugs
jetting (your main jet controls the top end fueling, so when you check your plug, clean it and put it back it, ride your bike at full throttle, turn off the engine at full throttle, pull clutch in, stop, remove spark plug, inspect it, oily plug = too big main jet, white = too small main jet, coffee color = perfect.)
clogged fuel system (clogged main jet, clogged petcock, clogged fuel filter) could be restricting the delivery of fuel in the top end when it requires the most fuel.
thats most of the possibilities listed.
Bike Owned: KTM 200 exc
Post by back off road » 01 Jul 2012, 01:41
if a dt 200 is outperforming your CRM 1 piece of advice GET YOUR CRM SORTED :!: :!: :!: :!: :!:
xander77
Forum Regular
Forum Regular
Post by xander77 » 23 Jul 2012, 20:22
Out performing is not really what I am saying, it just feels like there is more of a kick top end! plus the low end fells fine as well! might be the pipe on it, it does not leave me on the trails just felt there was more poke, open it up on the road and the DT lifts the front, mine just goes faster but without the clutch the front is planted!
jompy
Forum Ghost
Forum Ghost
Bike Owned: MK2
Post by jompy » 23 Jul 2012, 22:17
you should be able to get the CRM rolling pop it into second gear shut off the throttle yank the throttle back & the front wheel should pop up , well it did on my mk2 & i think it was on std gearing as it read just over 90mph on the speedo at top end
