crm mk1 ,2 & 2.2 side panels
- bungerlowbill
hi to one and all great site , as a idea as i know that side panel on airbox side is a crm only part ,but surely it might be possible to graft cr250 88-89 side panel over the top to give another colour , so you keep your std crm side panel intact cause of sealing lip on inside of side panel for the airbox , the other side panel is more easily modded to fit. regards to all
bill
crm250
1990 cr250 gas tank and rad covers orange
1991 cr125/250 front & rear fenders orange
dep full pipe
Lt sump guard
20x26x20 with seals outer swing arm bearings
20x26x30 inner swing arm bearings
bill
crm250
dep full pipe
Lt sump guard
- bungerlowbill
Re: crm mk1 ,2 & 2.2 side panels
Hi folks , well decided to go down the route of getting the side panels vinyl rapped to the colour wanted then yellow number boards applied afterwards, if this doesn't last i'll take the plunge and buy some new ufo 1989 cr panels and modify to fit regards bill
Good luck.
- bungerlowbill
Hello crm'ers , have got the panels rapped today, looks better than those plain white panels now in orange yellow number back grounds and had the air filter box panel on panel in black so it looks separate from panel , as a measure have hot glue gunned vinyl edges on under side to prolong lifting so this micht help others to mod std side panels on mk1 -2.2 from red or plain white still keep std airbox, cost £27 by print firm.
regards bill
regards bill
- bungerlowbill
Well here's an update ,still intact at moment, regular usage on roads so there you have it , still looks good ,cause i've not fallen off it, early yule tide greetings to one and all regards bill
