no spark
huntley
One Hit Wonder
One Hit Wonder
no spark
Post by huntley » 26 Jun 2017, 10:56
Hi all I have a crm 250ar and it hasnt been started for about 12 months. Went to start it and no go, checked everything and found no spark. I have very little voltage (about 1 v) going to the ignition coil from the cdi. Everything else checks out ok. Is there anything else I should check before scrapping it as a new CDI is worth more than the bike now. Cheers!
Re: no spark
Post by gregorious77 » 26 Jun 2017, 14:44
These are renowned for the Reg/Rec dying so would be looking at that first. Mine actually died on the lanes and the first I knew was my GPS saying it was no longer charging followed by a misfire and finally nothing. £90 to see you right if it is that.
Re: no spark
Post by fallenmikethebike » 26 Jun 2017, 18:12
Do you know anyone else who owns an AR?
You could swap your suspect unit on their bike and verify whether it's working or not.
PS. best not to test a known working CDI on your bike in case the reg/rec is blown.
