Coolant Leaking from Sidecover
John McD
Post by John McD » 29 Oct 2006, 11:44
I've just got the engine back together and back in the frame. When I filled the system with coolant, I found it leaking out what appears to be weep hole in the clutch cover, in front, down low. Looks like a purpose built hole. I took the side cover off, but couldn't find the hole from the inside, although I didn't get the water pump gear off.
Can anyone provide information that would help a yank to get a CRM on the road in the states. Would be much appreciated.
Bargos
Forum Regular
Forum Regular
Post by Bargos » 29 Oct 2006, 17:14
Hi John,
What model is it? I can take a look at my mark2 to see if thats any use to you.
B.
Bargos
'Daybreak Boys', West Sussex
John McD
Post by John McD » 29 Oct 2006, 17:54
It's a 1993 Mk2/2. The hole is in the clutch cover down low right above the boss for the bottom mounting screw for the water pump cover. Probaby about 1/32\" in diameter. Coolant will come out in a steady stream.
edarter
Post by edarter » 30 Oct 2006, 12:31
John - is it on the water pump case itself ? sounds to me like the bleed hole for the water system. Should be a screw in there (I think with a washer)....
HTH
Ed
John McD
Post by John McD » 30 Oct 2006, 13:07
No, it's not in the water pump case, it's in the clutch cover, beneath the water pump cover. The hole is not nearly big enough for a screw. It is literally a pinhole. It's located on the front of the clutch cover, facing the front of the motorcycle. I'll take a picture later today, although I'm sure the hole won't show up, it will illustrate the location.
Jonorow
Post by Jonorow » 30 Oct 2006, 13:27
That is a tell tale hole to tell you your waterpump is leaking!
when you put the case back on you may have damaged the outer seal, so take the case off and replace the waterside seal (May need to do both) also check water hasnt made its way into the engine.
What happens is the water gets through the one seal and drains out of the hole rather than being forced into the engine.
All waterpumps on engines have this hole. Jon
Bargos
Forum Regular
Forum Regular
Post by Bargos » 30 Oct 2006, 19:37
Good shout Jono.
B.
Bargos
John McD
Post by John McD » 30 Oct 2006, 20:27
Thanks, I spoke with a friend over here this morning that told me the same thing. He said to replace the seal and the shaft together. So I guess I'll be placing an order with LT.
Thanks for the help,
John McD
Pie-eyedpiper
Bike Owned: Mk 2
Re: Coolant Leaking from Sidecover
Post by Pie-eyedpiper » 13 Apr 2013, 14:01
I've got the same problem on mine.
Can someone please tell me precisely what needs to be replaced. I have never had the side cover off.
