mk 2 carb
mk 2 carb
after having starting problems on my mk2 i bought a new pilot jet and cleaned out carb. the bike now starts easily but runs like the choke is on full. the only way it will run something like reasonably is if i switch off the petrol. then as it starts running out it will rev and run properly. stripped it and blown it out a few times since, checked float height, all ok. if any one has had a similar problem i would be glad to hear from them.
thanks.
thanks.
- shemston_crm
- CRMR
i bet you have put it back together slightly wrong yet every time you strip it you make shure you put it back together the way it was , wich was wrong from the first time ,?????. It sounds like theres an o ring missing from one of the adjusters , , the emulsifier baffle is fitted wrong or the needle and sliders not fitted well ,
please read disclaimer in my sig ,,
- shemston_crm
had a similar problem on my old kx250,that turned out to be the needle valve attached to the float wasn't seating right due to debris between it and the valve seat.with this problem though i had fuel peeing out of the over flow,turn the fuel off,the fuel level in the carb drops and it would run o.k for a while.if you havent got a puddle of fuel under the bike then this probably isnt the cause however i'd check the overflow hoses to make sure they arent blocked
- shemston_crm
seems a common falt on crms at the mo ( yes mine does too sometimes!!!) but other times the bike runs great with no probs. stop it for half an hour then it pours fuel on your boots a bogs down when you ride on the flat........... CRF anyone? I am getting tempted, but cant be asred with the maintenace, so may look at an XR400....... or suffer for some great fun on the crm (when it runs) Jon
did any of you check the needle valves when you stripped the carbs?,if not then thats the first thing i'd go for.
take off the carb,remove the float bowl and hold the carb in its usual upright position.now blow down the petrol pipe while gently lifting the float,at first air should pass through the needle valve but the higher you lift the float the air should not be able to pass through it (you only have to apply light pressure to the floats to achieve this,so no vices,hammers,10 tonne presses etc )
if you can still blow down the petrol pipe then its definetley the needle valve causing the problem
check the needle valve tip (pointy end)for any signs of wear eg pitting,marks or i have seen them with complete grooves all the way around,any noticeable damage replace immediately along with the brass seat that it fits into(normally screwed into the carb body)
if no damage is seen clean the valve tip,then check inside the valve seat for crap,clean the seat manually blowing them out isnt always 100% then rebuild and do the above test again.if the airflow stops your ok if it doesnt then get a new needle valve, remember check your float height again when youve sorted it
dont know if any of you have ever stripped your tanks down,i did mine when i painted it a while a go and the rusty s**t that came out of mine was unreal,when i stripped the carb down for inspection a few weeks later it was full of the same brown s**t,im beginning to wonder if theres a tank seal fault?any way i'm going to fit one of those clear plastic fuel filters in the fuel line when i put her back together to stop it happening again perhaps you guys should think about this aswell
let us know how you go on
- shemston_crm
its a 91 mk2,but it'd been badly treated before i got it. it just struck me when reading yours and jonorow's posts that there may be a tank seal issue,dont know wether they use the same filler cap or not having never being up close and personal with a mk3
let me know wether this cures your fault shem
