Wiring to rear indicators
Hi, I have just bought a CRM that I would like to MOT, but the wiring to the rear indicators is missing. Can anyone tell me where abouts I pick up the wiring in the engine area?
I have 3 wires going to the back for the rear light, earth, side light and brake light, but nothing else, and I cant find anything that looks like its been disconnected or cut.
Also........the fornt indicators are in place and wired up, but nothing happens with the engine running and the indicators switched on. Is this normal or do I have another problem?
Thanks, wobbli
Thanks, wobbli
To start there should be a connector under the seat behind the cdi, it may have fallen down , its a 4 pin connector and this is the block for the rear light unit. sorry cant remember what colour the wires should be.
point 2, behind the number plate there is (should be) a large round rubber think with 2 wires red and green coming out, this is the capacitor and with out it none of the lights will work, if that is ok try the wiring loom from the indicator switch, maybe the wires have corroded (does happen).
Hope this will give you a start, good luck. Jon
Hmmm, another step closer. Your info was about right Jon. Found the connector, its got 5 wires, and also found a note scribbled on the back of the manual that the previous owner gave me. It says
Orange LH ind
Grey RH ind
Green Tail light
Green yellow earth
Brown brake
I guess those are the wires I am looking for, but as the bike is still largely in bits, I cant run the engine to try just yet. Cant find any evidence of the capacitor. Do you kown where it should be connected to?
It should be back in a running condition over the weekend so I will see what happens then. Thanks for the info.
wobbli.
Orange LH ind
Grey RH ind
Green Tail light
Green yellow earth
Brown brake
wobbli.
wobbli,what model crm is it?,mines a mk2 and doesn't have a capacitor for the rear lights
hears a link to a colour wiring diagram for the mk2 & 3
http://www.holidayinholland.org.uk/imag ... wiring.jpg
Thats brilliant slider.The colours pretty much tie in with what the previous owner had written on the back of the manual, and I am pleased about the capacitor. If the lights dont work now when I get the engine running, I think it will be down to corosion or faulty wiring, but I will post again after the weekend when I should have the bike back together.
Wobbli
Wobbli
if you take your rear pegs off and all the indys you can get a full MOT without indys (what i did with my CRM)
ZXR750 L1
1986 Maico GM 250
TL1000R
http://www.bikepics.com/members/zxr400rene/" onclick="window.open(this.href);return false;
1986 Maico GM 250
TL1000R
[b]rene :[/b]
That's true, and without the rear pegs you dont need a chain guard. Also if you remove the indicators you must also remove(or hide/tape up
) the indicator switch. Depends how keen the mot tester is.
Another thing is, if you remove the indicators and rear foot rest's, you cannot enter a Rally in the "trail bike class", but you can enter in the "sports bike class"
Mud, Sweat and Fear
91-MK2
91-MK2
[b]Gwyn :[/b]
> [b]rene :[/b]
) the
> indicator switch.
bit of black elecy tape over the switch got mine though!
> [b]rene :[/b]
> indicator switch.
ZXR750 L1
1986 Maico GM 250
TL1000R
1986 Maico GM 250
TL1000R
Pleased to say the bike is up a running again, and all the lights work bar the right indicators, which I think must be a bad connection, broken wire or something similar. Ran out of time to finish off, but all the other lights definitetly work, and without a capacitor at the back of the number plate. Perhaps the Mk2's dont need them? Anyway, should be in for its MOT next week sometime.
wobbli.
wobbli.
[b]wobbli :[/b]
> sometime.
> wobbli.
Well done Wobbli, and good luck with the MOT. I got a MK2, and there is no capacitor for the rear lights on mine
> sometime.
> wobbli.
Mud, Sweat and Fear
91-MK2
91-MK2
