Fitting rim locks
tomh
Fitting rim locks
Post by tomh » 12 Nov 2007, 15:42
I have just bought a pair of rim locks for my crm, how easy are they to fit and whats the lowest psi i can run pirelli mt43s with them?
Scoobie
Post by Scoobie » 12 Nov 2007, 20:21
If by rim locks you mean 'bead locks', then they just slot through the hole provided in the rim, and tighten-up fully when you've got the tyre back on fully and seated.
If there isn't a second hole in your wheel rim then you'll need to drill one out - no biggy, 10 or 12mm I think. I tend to put two rim locks on my rear wheel - one opp the valve and one just along from the valve.
Advisable to use some rim tape as well to cover the ends of the spokes, but carpet tape will do - just a pain to clean-up when your fitting a new tyre.
Regarding the tyre pressure - it depends where and when you'll be riding it. If there's a bit of road work required I find it's best to keep it at 10 or above (personal preference). If it's just off road it just depends on the conditions. You can take it down to 3-4 in the muck (just like trials) as long as you're not going for any big jumps or rocky steps.
Scoobie
tomh
Post by tomh » 12 Nov 2007, 21:21
Thanks, yeah i think there bead locks, metal things that cost about a tenner each.
Ive got 1 to go on the front and 1 on the back, is it advisable to get 2 as id imagine they can affect the balance of the wheel?
slider
Forum Bore !
Forum Bore !
Post by slider » 12 Nov 2007, 22:10
you wont need one fitted to the front in my opinion tom and i dont know any one that has,may aswell fit both to the rear i'd say.i only use the one rear and havent had any probs
Scoobie
Post by Scoobie » 12 Nov 2007, 22:27
Wouldn't worry too much about wheel balance with off road tyres on - you'll never get em bang on and you'd lose the weights anyway eventually off-road.
I only tended to fit two to the rear as a throwback from my old trials days running really low PSI.
Before you try and fit both to the back, make sure they're the right size/width for the wheel. From memmory I think they tend to get supplied as 1.8 and 2.00 - correct me if I'm wrong - with the larger for the rear.
Cheers,
Scoobie
mickstoy
Post by mickstoy » 12 Nov 2007, 22:37
[b]slider :[/b]
i have :roll: only cos when i asked the guy fromLT (or should i say salesman!!!) he told me that if you are running low psi and brakin hard over ruff terrain thats when the tyre could move but there again he was tryin to sell it to me
91 mk2
tomh
Post by tomh » 12 Nov 2007, 22:40
ill just fit one to each wheel at the moment as thats all i have, see how i go with it, if i get any trouble then ill have to buy another. its £10 i could do without spending right now, damn bike and cars are costing me afortune!
slider
Forum Bore !
Forum Bore !
Post by slider » 12 Nov 2007, 22:57
[b]mickstoy :[/b]
> [b]slider :[/b]
why???? and your ginger!
tomh
Post by tomh » 12 Nov 2007, 23:10
my locks are the metal talon ones, could they damage the tube?
Gwyn
Post by Gwyn » 13 Nov 2007, 09:21
[b]slider :[/b]
Same for me, just one in the rear :oops: :lol: :lol:
Mud, Sweat and Fear
91-MK2
