sticky power valves
- rikkster
sticky power valves
: 8)
gidday all. as with regard to sticky power valves ( only if its a mechanical freeze up, not electrical) it is possible to free up the valve by removing only the expansion chamber & rc cover. elevate the bike at an angle of about 30 deg ( rear end up) so as not to get any foreign material & liquids into the cylinder. remove valve actuator arm & cables. remove seal retainer & seal. position piston in t.d.c possition & sparingly use small amounts of carby cleaner to soften the carbon deposits around the valve shaft. into the exhaust port, (around the shaft both sides) spray an oil based lubricant & also where the shaft protrudes from the rc housing. persistance is the key as you work the shaft in it's full travel. beleive me , it's a lot easier to do it this way than remove the top end( it only took about 25 minutes & this i thought was'nt too bad considering it was frozen almost solid). hope this helps fellas.
cheers rikkster.
cheers rikkster.
\"IF YOU WANT TO BE DIFFERENT TO THE REST OF THEM, THRASH THE CRAP OUT OF A CRM.\"
