temp problems
jefftom
temp problems
Post by jefftom » 16 May 2008, 19:43
Can anyone help i seem to have a problem with my mk2 CRM 250 for starters it runs ok but when it warms up the temp warning light comes on when riding it then goes of then comes on agian if i am stanionary it goes of but upon reving engine the light keeps coming on and off any body got any ideas could it be the temp sender if so does anbody have one
jeff T.
many thanks
Jeff T.
freebz1122
Bike Owned: mk2 91
Re: temp problems
Post by freebz1122 » 21 Sep 2008, 14:43
if the temp light is coming on it could be coolant problem, air bubbles trapped, water pump not working or maybe running lean.
check the coolant level on the expansion/header tank and in the radiator.
you might want to drain the coolant out with the drain plug on the water pump.
you could flush some water through a few times and the put drain plug back on
fill the radiator with at least 30% antifreeze to water. (any water doesnt have to be distilled)
pour in very slowly to stop air bubbles forming.
if there is air bubbles in the coolant system run the engine with the radiator cap off but be very carefull.
run the engine untill the bubbles stop coming to the top.
then give it rev and see if any bubbles come up. (should be ripples not bubbles)
take bike for a spin and then when its cooled down check radiator coolant level and top up if needed.
or it might be running lean the air mixture screw should be about 1.25 turns out for an mk2
also check the spark plug and see what sort of condition its in. (website below for spark plug analysis)
http://www.gnttype.org/techarea/engine/plugs.html" onclick="window.open(this.href);return false;
