hand guards
hand guards
hello chaps does anyone know the best place to get some decent handguards from,had a couple of sets of the cheaper ones but broke them both on the clutch side (a long with the clutch lever ) cheers
Re: hand guards
please read the:flip wrote:hello chaps does anyone know the best place to get some decent handguards from,had a couple of sets of the cheaper ones but broke them both on the clutch side (a long with the clutch lever ) cheers
"Please read before you post a question." topic at the top of the technical board.
then a search for hand guards will quickly recommend http://www.oro2u.com
Re: hand guards
Did use the seach but the handguards on there look about as good as the ones i keep breaking. thanks
Re: hand guards
so can anyone recommend some handguards that are proven to take abuse
I guess the guy that falls off the most should be able to help...
Re: hand guards
I use these http://www.acerbis.com/p106_handguard/1325.html" onclick="window.open(this.href);return false; with a spoiler.
Re: hand guards
Have a closer look at the Off Road Only website, as they do a cpl models which incorporate aluminium bars inside the moulded plastic of the handguards. Look at the Pro Rally model. Not cheap, but if you break them, maybe you oughta take up something safer like indoor hang gliding or blindfold bull fighting!
Regards KK
Regards KK
- Davey Munroe
Re: hand guards
Hi Flip, I use ufo handguards with the ali insert that mount into the bar end aswell. In addition to this I fit short levers ( or shorten them), so that they come no where near the guards themselves. I've had some big "offs" directly onto the handguards, and not had any problems. All guards will move a bit on impact and this sometimes catches the levers and snaps or traps them, which pisses you off or costs time on a special. Fortunately you can get short levers for the CRM. This approach seems to work for me. Regards dave
