THC chain??
THC chain??
Hi as the title says anyone used a THC O-Ring chain? saw this http://cgi.ebay.co.uk/THC-O-Ring-520-H- ... 3a58b19d6b on eBay and it seems very cheap for an O-ring, is it cause the quality is poor? I know the answer is prob yes but if anyone has used this make it would be nice to know?
THC Chain
THC Chain
- 2016NWAA
Re: THC chain??
It is cheap because it is a Chinese brand. I have no experience of their chain.
I think the chances of it breaking are unlikely but the damage if it does can be high.
Could be worth trying?
My next chain will be a DID o ring. It may cost a bit more but I am expecting it to be value for money in the long term as it should last longer.
- delvey91
Re: THC chain??
I have just bought one of these, will see how it goes. No off road use so should be a while i hope!
99 HONDA CRM250 AR MUGEN
KTM 525 EXC SUPERMOTO 05
Re: THC chain??
[quote="delvey91"]I have just bought one of these, will see how it goes. No off road use so should be a while i hope![/quote]
OK let me know how it goes
Re: THC chain??
You have the case saver fitteddelvey91 wrote:I have just bought one of these, will see how it goes. No off road use so should be a while i hope!
From experience, Many years ago, I purchased at auction, a massive bench vice, which was something I needed at the time.
On inspection this vice was a Chinese import, and more than likely made from metal that had been hardened to the consistency of crackers[Chinese], one good clamping down stripped the threads straight of
Re: THC chain??
[quote="fallenmikethebike"][quote="delvey91"]I have just bought one of these, will see how it goes. No off road use so should be a while i hope![/quote]
You have the case saver fitted :?: :roll:
On inspection this vice was a Chinese import, and more than likely made from metal that had been hardened to the consistency of crackers[Chinese], one good clamping down stripped the threads straight of :shock: "Hoo, phlung Dung", was amongst the expletives flying around the garage, along with bits of vice.
Mike[/quote]
Whats the case saver??
Mike[/quote]
Re: THC chain??
Whats the case saver??[/quote]
Case saver is the sprocket cover - a sacrificial piece that takes the hit if the chain breaks and hopefully 'saves your case'...
- delvey91
Re: THC chain??
I was under the impression the case saver was the metal bracket btween the casing and the cover?? But yes i do have that fitted
Re: THC chain??
Delvey +1
Re: THC chain??
ahhhhhh
just off to check if I have one...
Re: THC chain??
ohhh crap I don't have one (ya learn somat everyday!)...only £9 from Lings through...that'll be on order tomorrow then!SkidMark wrote:ahhhhhh![]()
Re: THC chain??
SkidMark wrote:ohhh crap I don't have one (ya learn somat everyday!)...only £9 from Lings through...that'll be on order tomorrow then!SkidMark wrote:ahhhhhh![]()
- delvey91
Re: THC chain??
Re: THC chain??
I've just fitted a DID X ring on my gasser, after having a cheap chain let go on my RF I'll never buy a cheappy again and the DID wasn't that expensive
Re: THC chain??
tx for the pics delvey - I have the bit on the left but not the bit on the right!
Regards
SkidMark
Regards
SkidMark
