rear brake crm250 mr2
eddie666
Bike Owned: 1992 mk2
Post by eddie666 » 31 Jul 2010, 18:10
hi, can you change the rear pads with out taking the back wheel out ????
it looks like the disc has to be droped out of the way, any help would be great thanks eddie.
Re: rear brake crm250 mr2
Post by twistednuts » 31 Jul 2010, 19:35
Hi mate, yeah, dunno if its worth explaining how cos im rubbish tryin to explain meself, especially in court.. hahahaa, but i`ll give it a go...
Lookin face on the caliper, take out the the brake clip, then undo an remove the brake pad spindle, should be 8mm nut.
Then the pads should pull out. Puttin em back in is reverse of takin em out. Will need to push the piston back in cos new pads will be thicker. Put some copper grease on back of pads an spindle an your away.
