2 Stroke oil sensor
2 Stroke oil sensor
I have the same problem as this previous thread :
I'm sure it can be repaired / sealed with silicon, but does anyone know how the sensor is fitted into the top frame rail? It looks like a push fit, but I don't want to force it. Anyone got it out? Any idea of cost of replacement ?the sensor that plugs into the lower part of the resv was leaking around the wires and dribbling down the bike
- Ian T-B
hi millemg
Mine leaked some time ago. Silicoln will not do the job unless you can get it 100% clean - imposible. It is a push fit albeit very tight and you will more than likely damage it when trying to get it out - I did. I got a replacement one from LT off the shelf for around £25 - £30.00
In the long run its worth it as 2 stroke oil is expensive and it will only start to leak worse as time goes on.
Regards
Ian
Regards
Ian
