Boyesen reeds and location question
Sorry if the first part of this question seems stupid but I am new to two strokes and have only ever owned four strokes! I also cant seem to find the answer using the search function
Am I right in thinking that the reeds are located next to the carb on the engine side?
Do you take off the carb to access and remove the reed box?
Also, will Boyesen reeds number 633 fit a Mk2 1991 CRM250?
Thanks in advance... Il try not to take up too much time with questions!
Re: Boyesen reeds and location question
Yes you are correct on location. 633 will fit all CRM250s.
You can find more tuning info including this if you look in the FAQs..........
Thanks for the info.. Just wanted to check the Boyesen number before I part with some hard earned cash!
