Water pump Gear
- Carbguy
- Bike Owned: AR / Mk1
Water pump Gear
Hello!
Had a bit of an issue with my CRM rebuild... the water pump gear was cracked as i opened it and didn't look like it would need a replace.
Now as i was going for a ride the temp indicator lighted up several times making me check the problem. And yes i know, i know... if it's cracked, then replace it but...
i had faith on that little plastic peace would not let me down. But now i found it in bits after i opened the clutch cover.
Could someone please tell me the part nr of a new gear or which one would fit?
![Crying or Very Sad :cry:](./images/smilies/icon_cry.gif)
Re: Water pump Gear
What model?
Re: Water pump Gear
There is an AR parts manual in the FAQs
![Image](http://i183.photobucket.com/albums/x212/knackeredmk1/Capture_zps6b0830b2.jpg)
- Active Rascal
- Forum Ghost
- Bike Owned: CRM 250 AR
Re: Water pump Gear
Good old Steve!! You have to be extremely careful when assembling the clutch cover to ensure the gears mesh, don't force it. If it doesn't go, turn the kickstart gently by hand and try again. Repeat until it pops on. i didn't know this, but someone told me, luckily before I smacked mine to make it go on!!
- Carbguy
Re: Water pump Gear
Thanks again steve.
Man that was my fault. I was In a hurry. I should move to UK. Everything fits perfektly
An smoothly pops in overthere.![Wink ;)](./images/smilies/icon_e_wink.gif)
- Carbguy
Re: Water pump Gear
Cuoldnt find any parts near my location. That shaft of a CR500
Looks similar but i couldnt get rid of one to make a comparision..
Unless anyone has a sugestion, im forced to mashine a new one
Myself. Any ideas![Question :?:](./images/smilies/icon_question.gif)
Myself. Any ideas
Re: Water pump Gear
They are always cracking, due to heat mainly.
It will not crack up, it just shows cracks, no problem to keep using it.
LT refits them with hairline cracks.
- Active Rascal
- Forum Ghost
Re: Water pump Gear
Mine had cracks in you could just about Get your thumb nail in. LT said it would be fine but I choose to have a new one to be safe.
- Carbguy
Re: Water pump Gear
So for a guy who like me who lives in the middle of nowhere, what would be
The solution for my problem? Build a new one?
- Carbguy
Re: Water pump Gear
Yay!
Took that clutch cover to my good old buddy and he made a new waterpump gear
In no-time! Made of some bakelite and reinforced with a small bronze ring
Lets see if it cracks again. Now lets play seek n hide with the police again.![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
- Active Rascal
- Forum Ghost
Re: Water pump Gear
You're not supposed to re use the mechanical seal but you may get away with it.
- Carbguy
Re: Water pump Gear
I couldnt get the impeler off without using mayor force. The shop maybe tried to
Take it of, too with no succes. By turning the impeler with a tool, the shaft startet to slip
Inside the now broken gear. Thats why i decided to let it that way and just install the new gear.
Have some mercy AR
Have some mercy AR
