snapped crankcase bolt
following the guide - which suggested 6.8N -
Once all is well, tighten the bolts evenly in a criss-cross pattern to close the cases fully. Remove the bolts again, place a drop of thread lock on each and refit. Torque them up carefully and evenly. I'm not sure what the official torque setting is, I tightened them up to 8 lbs-feet (11 Nm) and only one broke! Try 5 lbs-feet (6.8 Nm).
have now snapped a bolt... case is back apart..
one step forward - 2 step back,,,
what should the torque be
Re: snapped crankcase bolt
bolts removed,..
actually I cheated, i didnt fancy my shoddy drilling, so went to a mates who had a drill on a stand!
result
nice one Badcat
he suggested not doing em up so tight
hmm my new small torque wrench only goes from 5Newts to 25
wondering if it was *tooo* cheap? ( about 25 quid new )
result
nice one Badcat
Not sure about crm bolts but berg bolts are 10Nm
25 quid doesnt sound too bad, as long as its calibrated.
snapped at 6.8
either
torque wrench is over doing it
or
bolts are crap
I just done em up so they feel tight -
ps anyone know if I can use hi temp copper compound instead of molydbenum?
either
or
bolts are crap
Are they the original bolts?
Just use the copper slip, you'll be rebuilding it again in 3 months
hahha - if that happens I rthink my wife will donate the bike on my behalf
I will be telling her big fibs about the flux capacitor melting down or summat......
at least next time I might have half a clue what I am doing?????
anyway - look on the bright side. it might not even last 3 months - could be end of june
