Crank seal stator side size
Hi all,
According to the forum the sizes for crank seals are 38x52x10 & 22x34x7... does anyone know which one of these is the stator side one?
... I want to order it ready so I dont have to strip my bike down twice!
Thanks....
Thanks....
Re: Crank seal stator side size
No-one?.... I only want to know big seal or little seal!
Not without trawling through shed loads of old receipts.Perhaps on this occasion be a little reckless and order both, if you don't need it now it will be used at some time in the future.
The stator side is changed from the outside anyway, so that can be done at your leisure.
A bearing factor outlet store will have an almost identical size for considerably less than a dealer outlet.
Sorry to be negative but it's too cold out in my garage for poking about looking for stuff.
Yep, the cold is whats putting me off taking it apart twice!
If you look in the part diagrams in the FAQs you might get the answer ................?
The Stator side is 22x34x7
Honda part number is 91203-KAE-003
Other one 38x52x10
is 91202-KAE-731
Other one 38x52x10
is 91202-KAE-731
Southerners ehfallenmikethebike wrote:Not without trawling through shed loads of old receipts.Perhaps on this occasion be a little reckless and order both, if you don't need it now it will be used at some time in the future.
