Help? Chain snatchy at low speed
Retro
Bike Owned: CRM250 MK2
Post by Retro » 17 Sep 2014, 10:37
Hi,
Cant seem to sort this one out, so any ideas welcome.
My Mk2 runs perfectly and I 'now' have very little issue with it( touch wood).
However, at slow speed/low revs the chain seems to snatch quite often and almost feel like it gets stuck for a moment???? Will only do it a low revs, fine all other times.
I have adjusted the chain (quite a bit) and checked the sprockets which all seem fine. Has anyone got any ideas?
I did wonder if it was the chain guide, but that also seems ok.
Perhaps a tuning issue?????
Help......
Mk 2 Supermoto
Mk 2.2 Enduro
helisupp
Bike Owned: CRM AR (4)
Re: Help? Chain snatchy at low speed
Post by helisupp » 17 Sep 2014, 12:03
Try turning the airscrew in 1/4 of a turn.
Retro
Post by Retro » 17 Sep 2014, 12:46
Thanks ....
I will check it out later, but I think it should be 1 1/4 turns out ?? But will see if its about right.
Mk 2 Supermoto
Mk 2.2 Enduro
Post by knackeredMk1 » 17 Sep 2014, 13:02
'Should be' is an estimate by Honda. Environment and the condition of the engine , intake and exhaust all affect this.
Heliupp is correct in that some fine tuning of your carburation will improve things but you might not get it perfect.
Post by fallenmikethebike » 17 Sep 2014, 15:01
It's also a a 2T trait, on a quiet piece of road or land try slowing down using both brakes, but holding on to a few revs on the engine, you will find almost all the chain slapping will disappear,as will the overrun pop, popping from the exhaust.
2T are only happy when their pulling, they loath even throttle, and decelerating.
Retro
Post by Retro » 21 Sep 2014, 22:07
Thanks chaps,
As you say, not perfect but slightly better.
Mk 2 Supermoto
Mk 2.2 Enduro
