Powervalve stopped again!!
Post by gregorious77 » 19 Oct 2014, 21:50
Heard the exhaust note change on the trails today and you guessed it the servo was no longer running.
Not checked it all out yet but my gut feeling is repaired PGM death! If so its off for repair again and chinese one on order for backup.
I have a love hate relationship with this bike.
Re: Powervalve stopped again!!
Post by fallenmikethebike » 19 Oct 2014, 21:58
Have you checked the operation of all the valves components? sounds like something is causing the brain to blow.
Post by gregorious77 » 19 Oct 2014, 21:59
yup lovely and free. cables all good, different servo.
Post by fallenmikethebike » 20 Oct 2014, 09:47
The reg/rec can also knock out the PGM, otherwise you've just been unlucky.
Post by knackeredMk1 » 20 Oct 2014, 09:50
FMtB +1
Post by gregorious77 » 20 Oct 2014, 15:34
I will also check the reg/rec but it was new when I got the bike last Dec.
Tonight I will mostly be in the garage with my multimeter!!
Post by fallenmikethebike » 20 Oct 2014, 15:41
Hhmmme, that's a pi55er. New, or new second hand?, genuine or Etrex?
Post by gregorious77 » 20 Oct 2014, 22:38
New Electrex from Wemoto in Jan 13.
Found problem with PGM! wire has come off board. not sure if its got hot and unsoldered or just vibrated off?!?
Reg/Rec off to work with me tomorrow for testing.
Post by gregorious77 » 21 Oct 2014, 12:16
REG/REC tested as fooked!!!
Looks like another 90 quid to spend then. and they say KTM means Keeps Taking Money.
CRM AR Continuously Requiring Money to Allow Riding.
helisupp
Bike Owned: CRM AR (4)
Post by helisupp » 21 Oct 2014, 13:46
Yep that got hot............
£90 plus a repair to PGM if it can be repaired
If you read FAQ you will see that you should always check voltage output of Regulator if a PGM fails.
When rebuilding my ARs I just put new ones on as a matter of course so I know everything will work.
Post by gregorious77 » 29 Oct 2014, 20:21
Fixed but lasted 10 seconds or so!
Going to give up on the Honda PGM and go for a STPS controller from Ignitech. Cheapest option and I can play with it too.
I know someone on here told me they run one on an AR with no problems.
pudzie83
Bike Owned: mk2 1992
Post by pudzie83 » 29 Oct 2014, 21:12
regulators going isn't just a crm problem its a honda problem ive had 4 separate hondas do it through the years
fireblade 900 one cost a few quid to fix it melted half the loom
