Waterpump Tool
- Speeddevice
- Bike Owned: Mk 2
Waterpump Tool
During the rebuild of my engine I couldn't find a good way to hold the waterpump shaft to under the impeller. There were also a few stress cracks in the plastic gear that are common. I tried using a screwdriver to jam the gear but wasn't happy that it wouldn't damage the teeth on the gear.
What I came up with is a socket that would fit over the gear engaging all the teeth. I made one on a 3D-printer, it has two tapped holes, the screws hold on a steel bar as a handle.
Worked perfectly
Worked perfectly
- Bike Owned: mk3
Re: Waterpump Tool
Hi there, welcome to the forum!
Nice idea for the tool. It took long time to design it?
I was using old t-shirt to hold the gear and used ratchet gun gently.
Good luck with rebuild
