Temp light
- frostoff
- Bike Owned: CRm250AR
Re: Temp light
I would check the sender if everything else is ok
- frostoff
Re: Temp light
Part no 37750-KV3-951 for the AR £54 from david silver spares
Re: Temp light
Wiring sounds duff, check the earth.
Re: Temp light
Whack a 75mm magnetic driven computer fan on one of the rads, it doesn't have to be pretty, but will give some peace of mind.Just wire it to be on permanently, they only pull a few watts.
Re: Temp light
Long runs at 50 mph see temps of around 60 deg C on my AR. Hill climbing or technical trails will get her up to 90-100 then its time to pin it or bin it.
Re: Temp light
CRM. AR. Could Require Massive Amounts of repairing.OZCRM wrote:Thanks for that I've just been on a run and temp was around 60 highest I got was 65. Temp light was on and off again when it came on I stopped and played with the wires behind the headlight and it went off, so think there is something behind there causing it to come on over bumps. Looks like I'll be pulling the headlight off and taking a look
