ConRod Quest
ConRod Quest
I have found a rod that is close but will keep on researching!!
Personal Watercraft KAWASAKI
Model JS/JF 650, Part No CR150, Ct to Ctr 133mm, Small end 22mm, Big end 32mm, Small end Width 22mm, Big end width 20mm, Pin Dia 24, Pin length 59mm, Small end bearing 18x22x24, Big end bearing 24x32x20, Big end washer thickness 1mm.
I am guessing the width could be machined down to suit the CRM and 0.5mm extra length will raise the compression ratio and change port timing but could be compensated for with a thicker base gasket.
- maciej_mi
Re: ConRod Quest
Chinese from aliexpress made con rod which looks same as OEM, if someone bought?
