MISFIRE
Nah, just wanted some flashy lighty things on itdouble_clutch wrote:ur talking about legal road requirements aint ya? sorry cant help u out there! rev counter whats one of them for?
...and R - glad that you've got it sorted mate (hopefully)...I knew that it was something to do pressure build up...honest
TiN
MISFIRE THAT WAS
Hi TEAM, BLOODY MARVELOUS COCO COLA!!!!!!, ITS SORTED THE MISFIRE, BETTER GET SOME BEER OUT!!!!!!!!!!!!, ONLY PROBLEM IS THE FACT THAT ALL THE REPEATED REVING HAS CRACKED THE EXPANSION CHAMBER JUST PASSED THE LARGER SECTION AND JUST BEFORE THE REAR FRAME MOUNT, SOUNDS GOOD THOUGH!!!!, AND THE WIFE WANTS TO KNOW WHY HER COCO COLA TASTES FUNNY!!, ONCE I GET IT TOGETHER PROPERLY ILL TAKE SOME PHOTOS, THANKS FOR ALL THE HELP AND SUGGESTIONS, BY THE WAY THE CR TANK FITS WELL WHEN YOU REMOVE THE TWO SMALL RODS THAT THE ORIGINAL TANK RUBBERS FIT ON, THE TANK THEN DOES NOT FOUL THE OIL FILLER CAP, I THE MADE TWO SMALL BRACKETS OUT OF PLASTIC AND BOLTED THE CR TANK VIA THE BRACKET TO THE MIDDLE RADIATOR MOUNT, AND FINALLY A NEW PAIR OF CR RAD SCOOPS BOLTED STRAIGHT ON, LOOKS GOOD,THIS WAS THE ONLY OPTION I HAD AS THE BLOKE I BROUGHT IT OF HAD LOST THE TANK??????!!!!!!!, WHAT A T..T
KIND REGARDS R
KIND REGARDS R
- double_clutch
- double_clutch
- jackstribe
- jackstribe
wiring diags
hello mate, email me on [email protected] with your address, i can photocopy a wiring diagram from my manual for you if you want.
Happy CRM'in !
- jackstribe
diagram
hello mate posted that diagram to you this morning should be there tommorrow.
Happy CRM'in !
