Loss of top end power + temp warning light
Thing is Bargos.......Bargos wrote:Say there is a crack in the head gasket between the cooling channel in the barrel and the combustion chamber. Under pressure, the water makes it way into the combustion chamber, past the piston and into the gearbox itself.
Thats how.
B.
On a 2 stroke, the gearbox is not in the crankcase. Its in a separate chamber, so to speak.
Me thinks you ought to look inside a 2 stroke engine sometime.
It may aid your usually good advice. (No poll required)
Thats how.........
- mikey11000
Re: Loss of top end power + temp warning light
I know this is an old post, but was this issue able to be resolved. My crm250ar is doing the same. Even from dead cold, the temp light comes on as soon as I rev the engine. I was going to try and find a new voltage regulator, unless anyone has a better idea.
- 2016NWAA
If the light comes on when you rev it and its cold you need to check the sensor, the switch or loose wires.boydees wrote:I know this is an old post, but was this issue able to be resolved. My crm250ar is doing the same. Even from dead cold, the temp light comes on as soon as I rev the engine. I was going to try and find a new voltage regulator, unless anyone has a better idea.
It is also worth checking that the rad is clean and not full of mud and that the thermostat is opening correctly.
In general bikes run cooler the faster you go as more air flows over the rads. The problem usually happens when you are stuck in traffic or struggling along a track with high revs in a low gear.
If the coolant level is not dropping then it is not leaking. Emulsified oil in the gearbox can be caused by water being sucked in through the breather pipe. If the pipe is hanging down and the hot engine goes through deep water water gets sucked in. The cure is to raise the breather. Even with the raised breather there is still a slight tendency for this to happen. Four strokes do not suffer so much because the engine oil gets hotter and moisture burns off as the engine gets hot
After checking Eddies sage advice above, consider fitting a fan, this helps enormously.
Thanks for the info guys. And I think I will invest in a fan, but this was an interesting one. After checking all the wiring etc, put bike back together and temp light was still coming on as soon as I revved it. Then I noticed the blown headlight. Replaced the headlight bulb and this fixed the temp light issue. Weird. I still have the issue with the power valve not working. I went through the testing procedures for voltage regulator and power valve motor and all seemed to be ok. I think it may be a dud PGM.
Greece needs you're wonga,right now.
Thanks Mike, excellent advice, I have been indecisive for days about sending it to nick. I am going to contact him right now.
