jetting
scrubs
Re: jetting
Post by scrubs »
If you can't get hold of a stopper, it may be cheaper to buy some boysenn 633's that dont need them.
sparky
Re: jetting
Post by sparky »
cheers
could that have caused any of the seizure problems??
it ran fine before iv used it at least ten times for a full days greenlaning each time since i got it this is the first time its broke on me?
what about if i made a little plate that ran the length of the reeds and fitted the screws through that would that work or does it need the cage really with the reeds i have?
Re: jetting
After market reeds tend to make only small changes to the jetting. If making only reed changes then usually only a maximum of one size up or down is needed (But it can be as much as 3 according to the Boyesen leaflet).
Eg. Boyesen reeds tend to make the pilot jet curcuit to run lean and the main jet to be rich. So need to turn the airscrew in a little or make the pilot jet bigger and reduce the size of the main jet.
Boyesen reeds have a much reduced stop plate across the base of the reeds as do many others. I do not know of any reeds that have 'washers' at their base as this would make a variety of stresses across the plates and would increase the likelyhood of failure :? :?:
NaBz
Re: jetting
Post by NaBz »
the boyseen reeds dont need them ??
Re: jetting
Boyesen reeds look like this -
They don't need the full metal plates.
sparky
Re: jetting
Post by sparky »
so if i make a plate up like the one in knackered's pic and fit that across the reeds rather than the washers which are fitted now then that should be ok?
i'll take a pic tommorrow of how they are done
so whoever changed the reeds before didnt know what they were doin :evil:
@ knackered i have also fitted an fmf gold series from a cr250 i think that alone should require some changes made from what iv read about them so far
thanks
that plate on them reeds
there is nothing like that on mine just washers underneath the screwheads
scrubs
Re: jetting
Post by scrubs »
sparky wrote:so if i make a plate up like the one in knackered's pic and fit that across the reeds rather than the washers which are fitted now then that should be ok?
It's difficult to tell, unless they were made at different tensiles and the aktivs were not designed to be stretched so far back?
If it hasent broken so far it may be OK with a metal plate, but then again, it's a gamble really, maybe phone Aktiv and ask -
see what they say.
Re: jetting
The washers are certainly wrong however I wouldn't guarantee that making a plate like that on the Boyesens will solve the problem. The reeds you have might need the extra suport of the original plates to stop them fatigueing (Sp?) when they are fully open.
You don't know what kind of reeds they are?
FMF pipes generally need leaner main jets (if any jetting changes), to get the most out of them but as yours is designed for a CR as opposed to a CRM then it is entirely possible jetting could go either way :?
sparky
Re: jetting
Post by sparky »
best to play with the jets either way then or get it on a dyno
i dont know what reeds were fitted in the first place but iv bought some aktive ones from leisure trail
do the boyessens come with the metal plates if so i may just buy some of them instead :?
Re: jetting
LT should be able to tell you what to do with the Activ reeds if they don't have instructions. BTW if you need the original plates I think I might still have some.
Boyesens come with the plate and instructions as to how to fit.
sparky
Re: jetting
Post by sparky »
there was some instructions but nothing about the plates i'll get onto lt tomorrow and see what they say if not i'll just get some boyessens and go from there
what sort of price should i expect to pay for the boyessens iv seen them on egay for around 35 plus postage is that about right?
cheers
Re: jetting
You can probably get them for ~£30 inc postage.
Boyesen Power Reeds CR250 1989 - http://www.racespec.co.uk/acatalog/Reeds.html
sparky
Re: jetting
Post by sparky »
:bow:
spot on thanks mate i'll stop with all the questions now :mrgreen:
Jonorow
Re: jetting
Post by Jonorow »
if you buy reeds and they dont have any plates then the original fittings should be Refitted (back plates) if like the boyesen they require a special fitting they will always be included in the kit.
98 (94) CRM250 MK3
96 ST1100PT
http://www.rymcc.co.uk
