2 stroke guru needed
slider
Forum Bore !
Forum Bore !
Re: 2 stroke guru needed
Post by slider »
john they usually smoke more when starting from cold,if it runs clean when warm i'd say you dont have a prob
Gwyn
Post by Gwyn »
slider wrote:john they usually smoke more when starting from cold,if it runs clean when warm i'd say you dont have a prob
I agree :)
Mud, Sweat and Fear
91-MK2
John crm
Post by John crm »
I agree :)
Thanks for replies. This is my fourth CRM, and it smokes a lot more than any of the others, on start up you could lose an elephant in it for the first 30 seconds or so !!!!!!!
I removed the oil pipe feed to the carb and marked the 2 stroke level, to see if oil was seaping through the pump and into the barrel, this was OK after one day, but I will continue to monitor.
I have also removed the exhaust, the expansion pipe was dry at the barrel end and oily at the other, the silencer was also oily. I hung these up to see if they had excess oil in, but nother came out over night.
With this off I had a look and feel ( ooh eer ) of the piston and rings, they looked ok but I could move the piston a small amount from back to front. I realise that this is the normal way the barrel wears, but on a good piston to barrel fit would this movement be felt ??????
:?: What 2t oil are you running.
Have you tried turning the petrol off when the bikes parked up , if the inlet valve is letting by slightly this excess fuel could find its way into the crank cases, this could in turn give rise to the pea souper on starting up, it may have no effect but its a nill cost check to run .
good luck
mike
John crm
Post by John crm »
fallenmikethebike wrote::?: What 2t oil are you running.
good luck
mike
The petrol tap is off, and I checked it sealed all OK, good idea though ! Running on Castrol I think.
Not castrol " R " .
John crm
Post by John crm »
fallenmikethebike wrote:Not castrol " R " .
No it doesn't smell that good, R takes me back to watching moto x
John crm
Post by John crm »
John crm wrote:
John crm wrote:Hi, After a run, I have a petrol/oil leak seaping from the lowest part of the exhaust on my MK2 project, the top end has a slight knock, i'm guessing that maybe all the fuel is not being burnt due to worn piston/rings. I'm planning on rebuilding the top end now i have got the MOT today. Apart from the small hole I must have on the exhaust weld, is there anything else I should check ?????? PS. She also like a smoke when giving it some !!.
Any helpfull advice will be appreciated. Thanks John
Ok, Done the plug test today, All OK plug a nice brown colour. Checked the oil pump setting, thats also correct to the manual. On start up, clouds of smoke, but when warm runs fine with minimal smoke. Unfortunatly found a slight weep from the petrol tank, that explains the petrol oil mix that was dripping from the exhaust, I'll have to fix this next .
I think when the bike is left for a week, the oil thats collected in the silencer is dripping back down into the front pipe, on start up this is then causing excessive smoke.
Thinking of taking off the front pipe for some investigation work, Any ideas ??????????????????????????????????????
Replace the oil pump with a new one, this has transformed the bike, no clouds of smoke on start up and running really clean. Thanks for all the tips
Result :D Was that an expensive fix?
:D
John crm
Post by John crm »
fallenmikethebike wrote:Result :D Was that an expensive fix?
£116 from LT, but money well spent. No more clouds of smoke, no more oil all over the back end, no more having to put working clothes on to ride it !!
Gwyn
Post by Gwyn »
Nice one John 8) :)
Mud, Sweat and Fear
91-MK2
slider
Forum Bore !
Forum Bore !
Post by slider »
nice one john,would never of thought of it!,ouch on the pump price though
