Front Fork improvements
lgingell
Bike Owned: CRM 250 AR W
Re: Front Fork improvements
Post by lgingell »
you asked what forks fit the crm yokes - wp 43mm usd forks (from bikes like ktm exc) fit directly into crm yokes with no modifications.
the complete ktm front would be needed (brembo brakes and all!)
i have a set to fit, but havnt sorted out a speedo drive yet.
eddie - yes, 15wt oil is too thick but as you will probably know the standard forks "blow through" most of the travel very quickly - the thicker oil helps slow this down slightly but it is a crude fix - improving the shim stack or changing the forks for something better is definetly what i want to do.
the crm is used for daily commute, trails, mx, enduros and hare and hounds
Bike Owned: KTM 200 exc
Post by back off road »
easy speedo fix = trail tech no drive needed or even a digital push bike speedo
BaNZ
Bike Owned: CRM250-MK2 '93
Post by BaNZ »
[quote="lgingell"]what forks fit the crm yokes - wp 43mm usd forks (from bikes like ktm exc) fit directly into crm yokes with no modifications.[/quote] - someone, please, explain this to me. But CRM fork stanchions 45mm, isn't it?!
43mm is the width of the 'slidy' chrome bits.
BaNZ
Post by BaNZ »
Damn me, knackered, but I can swear, on Mk2 was 45mm! I checked it myself. Don't know about mk3 though.
Igingell is saying that WP 43mm forks fit CRMs. Not that CRM forks are 43mm.
BaNZ
Post by BaNZ »
Ah! So there is difference among manufacturers! Okay.
Pie-eyedpiper
Bike Owned: Mk 2
Post by Pie-eyedpiper »
Fitted CR250 '91 forks to my mk2. They are far firmer, but I might reduce the oil level to soften them up slightly.
What surprised me was the original CRM yokes are slightly larger than the CRs. This made making them fit "fun". But eventually used some 1mm galvanised metal strip to use as a sleeve inside the yokes..
I think you might have got the date of manufacture wrong (or the supplier did) :? . The pair of '91 CR250 forks that I got fitted straight into CRM yokes.
Pie-eyedpiper
Bike Owned: Mk 2
[quote="knackeredMk1"]I think you might have got the date of manufacture wrong (or the supplier did) :? . The pair of '91 CR250 forks that I got fitted straight into CRM yokes.[/quote]
Hmmm, maybe they are newer then. They were definately smaller, bit surprising really, I expected to have to get my yokes machined out.
Possibly older. What adjusters do they have on :?: .
Pie-eyedpiper
Bike Owned: Mk 2
Turn screw on the top and a large adjuster in the bottom of the fork leg, not sure if screwdriver or socket.
Should be a flat head adjuster inside the large nut on the base of the fork. This is a compression damping adjuster. More clockwise - harder damping.
If it is just a flat head (though it could have been replaced with a crosshead) on the top of the forks then it is likely to be an air pressure relief. The '91 forks should only have these but so did the previous forks.
