Post by knackeredMk1 » 29 Mar 2012, 19:59
These are the XR400 forks off the original Mk1 project with the original yokes milled out to 43mm. I fitted brand new XR400 forks to the original project bike having revalved and resprung them to the same options. Compression damping reduced harshness, 0.45 Eibach springs and 5wt oil to standard level. New steering head bearings.
Post by knackeredMk1 » 31 Mar 2012, 14:44
Put XR650 wheels on and started today - easy peesy ;) . Now I've just got to fit the brakes and rewire the brakes and lights - I hate electricals :x .
++++ Arrival of seat. I've found it impossible to get a decent seat (CR not CRM) so I've bitten the bullet and splashed out on a new CR500 one from Honda :shock: . Unforunately they keep putting back the delivery date. - First it was 15 March, then the mid 20s March, then 2 April, now it's mid May :evil: :evil: . I was going to put the new seat on my other bike and use the one currently on that for this bike and cut down the foam a bit.
Post by knackeredMk1 » 09 Apr 2012, 03:56
Cancelled the new seat. I've found another CR500 one from the US, same year but with a torn cover and the fixings damaged. I'll be modifying those bits in a way that will make it unuseable as a CR seat, so I hope it will be fine. Seemed a waste to wreck a perfectly good seat and this way will be cheaper :) .
Post by fallenmikethebike » 09 Apr 2012, 13:46
Result, good thinking batman.
Bike Owned: KTM 200 exc
Post by back off road » 10 Apr 2012, 19:42
lightly modded :?: maybe this one needs a new title like jerams :lol:
Post by twistednuts » 10 Apr 2012, 22:49
:D
Yeah, was thinkin the same
I thought he was just gonna put a back rack on
Post by knackeredMk1 » 11 Apr 2012, 21:56
Having problems bleeding brakes.
I managed to get some pressure into the front and then zip tied the lever back to the bars to pressurise the system. Left for 2 days and now pressure is good.
I just can't get any pressure into the rear though. Got the fluid going though and sucking from the slave cylinder end, but absolutley no pressure on the pedal :evil: . Spent about 2 hours on this. It was really difficult on the other bike as well but I had done it by this time................
Post by twistednuts » 11 Apr 2012, 22:28
Try just pressing the pedal gently, with bleed nipple tight, but fluid res top off. Press slightly an keep it in one position for a bit.
I find when doing this that tiny bubbles come back into the res. Then it seems to create enough pressure to bleed via the nipple
Active Rascal
Forum Ghost
Forum Ghost
Bike Owned: CRM 250 AR
Post by Active Rascal » 11 Apr 2012, 22:34
Can John help? ;)
Post by twistednuts » 11 Apr 2012, 23:38
John is the front brake boss, not sure how he is with rears :shock:
john7780
Bike Owned: crm 250 mk2
Post by john7780 » 12 Apr 2012, 14:47
im going to refrain from swearing as im more mature than you fudgers
Post by knackeredMk1 » 12 Apr 2012, 14:59
Don't need John's help anyway :P .
I took the caliper off the back and held it up so the brake line went vertical. This seemed to clear the air and the back brake now works ;) .
Jeram
Post by Jeram » 16 Apr 2012, 02:05
back off road wrote:lightly modded :?: maybe this one needs a new title like jerams :lol:
Its gone serious because he's just realized that he needs to pull his socks up if he wants sticky status too LOL
Looking good mate
Post by knackeredMk1 » 16 Apr 2012, 10:20
This version will never make a 'Sticky' as it's a copy. A sister to the first Mk1 if you will ;) .........
Post by knackeredMk1 » 19 Apr 2012, 10:28
Only seat to go and some setting up :) -
