Front Wheel Bearings - Recommended replacements!
Not paid by them or anything but just changed my front wheel bearings and got them from here:
http://www.thebikebearingshop.co.uk/
You'll need 2 x 60032RS for the front wheel. They were made by NTN.
The 2RS means they have 2 rubber seals, so both sides...my old ones must've been plain old RS as they didn't have any seals on one side. Should help them last a bit longer I hope
Including swift postage they were £12.84, good service!
You need 2x ...32005x... I don't know what the other numbers refer to. I'll dig the box out of the garage bin when I get home and see which ones I got.
I accidentally found a way of getting the old ones off, I started with a little \"Dremmel\" type thing grinding the old bearing off(after removing the cage and rollers). After a few minutes I'd got a groove running ALMOST vertically up the bearing, thought I'd try hitting it with a Hammer and old wood chisel.
Two light blows later and the bearing twists off up the spindle.piece of...
Thanks for that info Dibble
There is a What fits what topic a while back, it contains a few useful bits of information.
Click Here
Click Here
