Slasher
Post
by Slasher » 30 Mar 2007, 22:49
tired of waiting for engineer for my laithe work,so I got side tracked by a veradero 125, after measuring three set's of wheels for crm specs I 've kind of got an eye for it, its rear wheel looks so promising so I researched the specs ,they seem to match even the disc and sprocket so I've got one coming £50.its a nice 3 spoke one 17\" a matching front can be sourced from a cbr6/9,vtr,hornet.making the front fit is no prob just wheel spacers and afew washers on the caliper.obviously I'm going digital on the speedo .
Gwyn
Post
by Gwyn » 30 Mar 2007, 23:31
Well done Slasher
Good work mate
Mud, Sweat and Fear
91-MK2
slider
- Forum Bore !
Post
by slider » 31 Mar 2007, 08:15
slasher if you go digital on the speedo front,have a look on fleabay at the push bike speedos.i found one on there that looks and does exactly the same as the trailtech enduro unit unit for 99p +£6 postage the trailtech retails for around £60.would have posted the link but i can't seem to pull it up so you'll have to browse
abigsupermoto
- Bike Owned: MK3 CRM
Post
by abigsupermoto » 31 Mar 2007, 14:30
I have just got a solar power digi speedo from Lidle for 5 quid, I haven't fitted it yet but it seems up to the job and you can put two wheel sizes in for when you change wheels 8)
Slasher
Post
by Slasher » 04 Apr 2007, 21:18
cheers slider but I'm already on abigs idea but im mixing the magnetic reed switch with an led 7 segment display unit available from Maplins electronics for £19.99 should register up to 99 mph [a crm's max] unless yours is better.flashy double digit display should look good.might go for blue led's.no wheel yet but I'll keep you posted,oh it should fit perfectly in original speedo display.
Bargos
- Forum Regular
Post
by Bargos » 06 Apr 2007, 09:35
lidl are doing some cheap multi function bike speedos at the moment, i can recommend the 12.99 model, works really.
B.
Bargos
'Daybreak Boys', West Sussex
Bargos
- Forum Regular
Post
by Bargos » 06 Apr 2007, 09:37
lidl are doing some cheap multi function bike speedos at the moment, i can recommend the 12.99 model, works really well.
B.
Bargos
Slasher
Post
by Slasher » 10 Apr 2007, 21:25
I'll try and get one on wednesday. cheers bud.
Slasher
Post
by Slasher » 02 May 2007, 18:09
veradero 125 wheel looks good, needs 11mm off brake disk side , 7mm on sprocket with spacer, then 3 spacers.standard wheel takes a 130 tire anyone know how big i can oversize ,150 would be good.VTR 1000 firestorm front wheel maiches with looks but the weird thing is they only have a 120 tire but the rim is wider than the veradero rim.I might fit a 110 tire to this so that everything looks in the correct proportion+ I may go a higher profile on the rear.
purple rooster
- Bike Owned: Mk3 prospec
Post
by purple rooster » 02 May 2007, 20:32
go for it slash dont forget the pics, sounds like y'v done your homework should look ace
ayup duck! livin on the edge................of a big rut!
abigsupermoto
Post
by abigsupermoto » 03 May 2007, 08:56
I am running a 160 goldspeed on mine, there are some differences with sizes between diferent brands, a 150 will be no problem
Slasher
Post
by Slasher » 30 May 2007, 13:51
they have made half the spacers and finishing the rest during the next week, cant wait,but I still have to officially my insurance wont cover me,this runs out in 5 weeks so they can change my company then for one that does.officially!!
Slasher
Post
by Slasher » 30 May 2007, 13:53
the wheels are going to be my crome 5 spoke cagiva ones that I first started months ago.
