oil seal
hoodlum
oil seal
Post by hoodlum »
hi guys, anyone know how to remove the clutch pin/shaft so that i can replace the oil seal. my bike is bleeding red liquid!! :?
scrubs
Post by scrubs »
Where is it leaking from?
check on the oil tank to make your its not coming from you're oil sensor
as I'm experiencing the same prob myself - but have drained the tank now and am about to order a new one.
I'm with Scrubs on this. Are you sure where the oil is coming from?
baker21
Post by baker21 »
[quote]my bike is bleeding red liquid[/quote]
wouldnt have thought it was engine oil then if its red.As above sounds like its 2 stroke.
hoodlum
oil leak
Post by hoodlum »
its definately coming from the clucth pin/shaft where it fits into the engine, but i,ve removed the cable and cant seem to get it out to replace the seal :(
could it be siezed to the brearing inside, if so gentle persuasion with what?
cheers guys
Jonorow
Post by Jonorow »
viewtopic.php?t=3099
just responded in the general tab. Jon
98 (94) CRM250 MK3
96 ST1100PT
http://www.rymcc.co.uk
hoodlum
Post by hoodlum »
cheers jon
