drz brake lever fits
drz 400 rear brake lever fits with very little work gets rid of the oringinal nasty steel one
Re: drz brake lever fits
Worth knowing 'but er i quite like the nasty steel onejapexup wrote:drz 400 rear brake lever fits with very little work gets rid of the oringinal nasty steel one![]()
know wot you mean bud but they do look a bit budget!!!!!! and the drz rear caliper fits too
DRZ front lever doesn't fit though!!!
i know got a new mastercyclinder from an drz s and my rallye short lever did,nt fit so had to keep with the suzy one
- shemston_crm
looks much better what was involved to make it fit?
its a doddle to fit the hole size in the lever are the same all you need to do is make a small spacer to go between the brake arm and the frame,either use the bottom off the drz cylinder or drill out the crm one as the clevis pin is bigger,plus nip a little bit off the threaded section on the rear cylinder to allow to get the lever set to the right height and use a shorter spring
