AR wiring - part deux
- raveydavey
Righto - Wiring to relays
New wiring to "nacelle" (cheers FMTB
) is nearly complete with only the wiring to the LED relay causing some head scratching
A 3-wire connector comes off the main loom and plugs into the LED relay (3 plug and 4 plug connectors) according to the wiring diagram. Only problem is, I can't work out the order of the wires, or what colour the 3rd wire is
(t'other 2 being "black" and "green with reddish stripe". By a process of deduction that Sherlock Holmes would be proud of, the 3rd wire is either "green with blue stripe" or "black with green stripe".........possibly.
Can anybody shed any light?
Cheers RD
Cheers RD
Re: AR wiring - part deux
Well on mine it appears to be 1 =black 2 = grn/red stripe 3 grn / blue stripe .
Hope this helps
fallenmikethebike wrote:Hi R.D , listen when i get a chance i will pop out into the garage and have a quick look .the problem is ,that I'm a bit busy as i have all these bl@@dy boots to clean , and the boot cleaner's let me down again
,you know how it is , staff ,eh .
Hope this helps
- raveydavey
KK - ...................be a man.................and do such a bad job you'll not be asked again.........works for me every timekernow krusty wrote:fallenmikethebike wrote:Hi R.D , listen when i get a chance i will pop out into the garage and have a quick look .the problem is ,that I'm a bit busy as i have all these bl@@dy boots to clean , and the boot cleaner's let me down again
Hope this helps
Mike![]()
HUH! Only MtFB could keep his under crackers next to his boots... then he wonders why the Kernow Boot Fairy hasnt visited!!!
FMTB - Ta for that - just to clarify, would that be 1 ,2 ,3 from left to right as looking at back of plug with catch bit on top - as shown below??
Cheers RD
O/k ,on mine standing on the left ,and front of the bike ,the colours running from left to are , grn/blu--grn/red--black
the black wire on the right is above the red/black ,which in turn is above the yellow of the connector block below .
Now if i had a bit of mud left i could really make it clear
which no thanks to KK i haven't
Just so as there are no errors ,i have clearly labelled the dubin pot, and the persil pot , otherwise i can see now how crest fallen KKs going to be when he presents me with my freshly dubined y fronts
- raveydavey
Clear as a muddy Cornish MX track that's been churned up by a 1000 Cornish MXers dubin-ing Y-fronts and persil-ing bootsfallenmikethebike wrote:O/k ,on mine standing on the left ,and front of the bike ,the colours running from left to are , grn/blu--grn/red--black
Now if i had a bit of mud left i could really make it clearwhich no thanks to KK i haven't
