small end bearing
small end bearing
hi guys i need a new small end bearing for my bike are they just crm specific so can order one direct from honda or piston specific?
thanks in advance
thanks in advance
- Furnuts
- Bike Owned: MK1
Re: small end bearing
which model CRM is it, and do you have stock conrod and piston? i would recommend getting out a set of calipers and measuring the bearing you currently have. inner, outer diameter and width. you can probably get one from LT or just do a search online and source one. Make sure you measure twice before you buy the part.
