Balance shaft
Balance shaft
I have read through the what fits what post but I am unable to determine if the balance shaft and drive gear are interchangeable between the Mk2 and Mk3. I need a gear and woodruff key and there is a whole unit on ebay at present.
Also I seem to be unable to find things with "search" at present, is this my technique or is there a common problem at present.
Keith
Keith
Re: Balance shaft
I would think that all balancer shafts are interchageable but don't know for sure. They are different part numbers but that is no certancy of difference. Leisure Trail may know
'Search' is a bit hit and miss at the moment. Don't know why
. - Have told Admin.
Re: Balance shaft
Thanks for the reply, I'll try to remove the balance shaft today to inspect the bearing surface. I suspect that is the reason the drive gear was removed in the first place.
Keith
Keith
