about bearings
kostas
about bearings
Post by kostas »
I need someone to confirm that the front wheel bearings for AR are 17x35x10 (6003) and top and bottom head bearings are 26x47x15 (32005x/26).Does anybody know dimensions of front wheel seals and head top and bottom seals?I dont want to buy them from honda dealer,i think they are overprized!
Re: about bearings
kostas wrote:I need someone to confirm that the front wheel bearings for AR are 17x35x10 (6003) and top and bottom head bearings are 26x47x15 (32005x/26).Does anybody know dimensions of front wheel seals and head top and bottom seals?I dont want to buy them from honda dealer,i think they are overprized!
Hi Kostas
I did replace my front whel bearings, but was remiss in not taking a note of the bearing nb , i believe one was a 6202, but the safest plan is to knock old your old bearings and replace with same nb , ditto with the seals as well , that should carry a size and width , or measure them yourself ,you may wish to try these people for new bearings .
http://simplybearings.co.uk/shop/advanc ... rds=hk2012" onclick="window.open(this.href);return false;
by the way some of those really cheap bearings on ebay can be a false economy , as they don't last ,and whilst mr H s bearings may be dearer they will probably last longer, but i don't know what mark up your dealers putting on spares.
Can't help on the steering stem bearings , i haven't had to change mine yet !!! however , when the time comes i might investigate some roller bearings , as opposed to ball bearings.Regards Mike
kostas
Re: about bearings
Post by kostas »
Thanks mike,i think am going for the pivot works kit for xr 400 front wheel from local dealer(cost 25euros).For the steering stem am thinking of buying two quility 26x47x15 (32005x/26) bearings(SKF or FAG)and genuine honda seals from honda dealer.I ll let you know what happen as soon as i have news.
kostas
Re: about bearings
Post by kostas »
Pivot works Front Wheel Bearing Kit PWFWK-H13-046 for Honda XR 400R 1996-2004 • Honda XR 600R 1993-2000 • Honda XR 650L 1993-2008 • Honda XR 650R 2000-2007 fits perfect.17 x 35 x 10 6003 bearings but did not have the chance to measure the seals.
