engine rebuild
engine rebuild
i got to put new crank bearings and seals in my mk2 is there anything else i should do while im in there cheers Dan
Re: engine rebuild
Check all bearings.
Check wear on piston, rings and bore.
Check balancer shaft for wear.
File away worn tines on clutch basket with a smooth file.
Check for broken teeth on gears and worn dogs on gear change and finally selector drum.
I.E. In case I've missed something - Check everything.
Replace crank seals as a matter or course and check all other seals.
- woolley
- Bike Owned: AR
Re: engine rebuild
Doesanyone know off the top of there head howmuch sideways movement is accepable on the conrod i have an ar with a rattle so i changed the little end which has not done the trick . iam also told you have to buy the whole crank HELP
cheers
Wool
cheers
Wool
