crm no spark
djron
crm no spark
Post by djron »
hi there still having a problem with my lads crm 250 no spark
changed the cdi reg/rec also coil and new plug
a guy used his meter at the coil wires and when you kicked it over the reading was from 30 to 40 volts dc i dont know if thats the way to test it but i would of thought if there is power to the coil wires then theres power getting throw the rest of the circuits magneto reg/cdi etc any help thanks ron
briangoo
Bike Owned: mk2 j reg 91
Re: crm no spark
Post by briangoo »
keep an eye on kramers post as he's having bother with no spark but 30-40 volts does sound hi to me
djron
Re: crm no spark
Post by djron »
[quote="briangoo"]keep an eye on kramers post as he's having bother with no spark but 30-40 volts does sound hi to me[/quote]
ok thanks ordered new coil on fri so will let you no what the out come is thanks
scrubs
Re: crm no spark
Post by scrubs »
Might be worth checking the stator if the new coil provides no joy.
This might help if you are unsure how to go about it - Although I am not sure of the stock resistance specs of the stator.
http://www.youtube.com/watch?v=rCqojU5wHos
scrubs
Re: crm no spark
Post by scrubs »
oh and before doing any of that or spending any more money.... Check the kill switch!
check it for continuity or completely bypass/short it while testing.
That would sound far more likely than the stator or coils failing.
djron
Re: crm no spark
Post by djron »
[quote="scrubs"]oh and before doing any of that or spending any more money.... Check the kill switch!
That would sound far more likely than the stator or coils failing.[/quote] seems theres power at the kill switch also power to the coil wires thanks ron
scrubs
Re: crm no spark
Post by scrubs »
Hmmm....Bad earth?
djron
Re: crm no spark
Post by djron »
[quote="scrubs"]Hmmm....Bad earth?[/quote] i just to add bought new coil still no spark all that is left is the stator anybody got one for sale thanks ron
briangoo
Re: crm no spark
Post by briangoo »
check out kramers post we ended up swapping my pick ups (mk2 his ar) that sit above the flywheel & it worked. good luck
