Engine oil level?
Olie
Engine oil level?
Post by Olie »
hi, how do you chaps check your engine oil on mk 2's?, there is no dipstick or level window , do you just have to empty the oil and put a certain amount back in?
Thanks , Olie
Re: Engine oil level?
Post by twistednuts »
If you look down then to the right of the oil fill cap on the engine, you`ll see a 10mm nut with a phillips head.
With the bike straight up, remove this nut, fill with oil till the oil starts to flow out of the hole, then replace nut.
SkidMark
Post by SkidMark »
just to add that you should leave the bike upright and let it finish draining from the oil fill hole before reinstalling the oil level plug.
Regards
SkidMark
Olie
Post by Olie »
Thanks alot guys this one had me scratching my head for quite a while...
